Adapted 60mm vs MFO on Sony
Featured Replies
I have the 90mm and port, which I understand can also fit the Canon 60mm and metabones.
It's my intent to adapt the Canon 8-15 at some point in the future so the adapter is coming one way or another.
Other than a bit of vignette on longer shots and the ability to shoot two FL on one dive, is there any other reason to prefer the MFO?
I've used the Canon 60mm but not the MFO-3 yet. The 60mm on full frame behind a flat port doesn't give the best image quality. It's useable, but from what I've seen, the MFO-3 should be better. The 90mm + MFO-3 is also wider than the 60mm, and it can focus closer. And native autofocus may offer some advantages versus the adapted 60mm. Adding in the versatility of being able to switch between the 90mm and MFO-3 underwater, to me, the MFO-3 seems like the more desirable option.
The Canon 60mm macro is an APS-C lens and using it on an APS-C system should be decent and gives you 90mm focal length which is +/- a standard macro lens for an APS-C system, while the 90 mm is 135mm equivalent and in my mind a bit long for an APS-C system unless you are shooting mostly very small things. I don't recall but I'm guessing you shoot APS-C Sony?
Assuming APS-C Sony, to make it more difficult to work out what to do, I expect you could use the MFO3 on the 60mm lens as well, I know it certainly works well with my 60mm olympus macro lens and gives you a decently wide view which would be better if you are shooting weedy sea dragon (400mm long ) size critters if you expect to encounter critters in this size range. You would of course need to check it will work - Nauticam have remove dthe EF-s 60mm from their port chart, but the Nikon 60mm macro is listed on the that chart as working with the MFO3 so I expect it probably should work as long as the flat port fits well. You could check for vignetting on land. It might also work with the Zeiss 50mm macro which has a few fans on this site as I recall, but again you'd need to check for vignetting.
Having said all that the big attraction for me is carrying a wider view with you when shooting macro.
  • Author
The Canon apparently only vignettes slightly on Sony FF bodies and only at distance. The idea would be for a wider lens.
Interestingly the little 30mm Sony ASP-C macro covers a larger area of the FF sensor than you'd think and is quite fast. So if I can find a port to fit it that would be a wider option that can basically focus on the glass.
Edited by Grantmac
  • 4 weeks later...
  • Author
I have acquired the metabones V and the Canon 60 EF-S for a pretty moderate price. As reported only minor vignette at distances which are beyond what our local visibility will allow. It has probably a 20mm gap to the front of the port but still a good 5cm of working distance and focuses fine with a +6 diopter as well.
AF struggles in low light but that's every lens. Seems just as fast and possibly less breathing than the Sony 90mm.
Going to do a test dive tomorrow.
I have a Canon 60 as well that I often use on black water dives with my a1. I find it focuses as well or better than the 90. The find the lens length is a good option just like the Nikon 60. As I use it for blackwater any vignette is not an issue. Ironically I use the Nauticam 90 port for it as well.
  • Author
Do you use the MC-11 or Metabones?
I use the Metabones. There a catch on the lens that does not work with the MC-11.
  • Author
Are you using it in Green or Advance mode?
I normally use Advanced mode due to occasional video. With that said, I have not seen a focus difference between Green and Advanced for photos with newer bodies.
The Metabones adaptor has both a White and Red mark for the mounting the lens. As the 60 is an APS-C lens it matches the White mark. The Red mark is for EF full frame lenses. (i.e. Canon EF 8-15 or EF 100 macro)
  • Author
Thanks! I don't do macro video so I'll have to give both a try. Tempted to design a focus gear to try DMF which requires Advanced mode.
  • 3 weeks later...
  • Author
I was NOT able to get Advance mode to function well, lots of ficus breathing even with good contrast and light. Green mode worked better but seemed to be slow to close the aperture and fire the shot.
Updated the adapter firmware and HUGE difference. Advanced mode now works far better, maybe a bit better in Green mode.
I'll be looking to 3D print a zoom gear since I can now use DMF with Advanced mode.
On 5/1/2026 at 5:15 AM, Chris Ross said:
The Canon 60mm macro is an APS-C lens and using it on an APS-C system should be decent and gives you 90mm focal length.
The Canon EF-S 60mm Macro is a very affordable and pretty much underestimated macro lens. The above, written by Chris is true for Canon Mirrorless full frame bodies, as the Canon MILC will auto-switch to 1.6x Crop mode. There is a work-around for this, by setting your desired aperture first and then slightly unrotating the lens from the bayonet. This will trick your Canon to consider it as a manual focussing third party lens.
Surprisingly it will only exhibit very little vignetting on a full frame sensor.
But you have to live with using it as a fully manual focus + fixed aperture lens throwing the very fast and silent AF of this lens over-board. Sony, MFT and Nikon users can adapt this lens with full AF features and will have it working as a full frame lens with slight vignetting in some focus positions.
Ahh,.. and if you intend to use it for video the 16:9 aspect crop will also help to get rid of the dark corners on a full frame body.
Edited by Adventurer
