“Wrap Around” Float for Backscatter HF-1?
Featured Replies
10 hours ago, Dave_Hicks said:
I dove today with an HF-1 + Float and Atom with Snoot. The HF-1 was weightless
How did it “feel” in water (balance, etc.) vs no collar and more traditional arm floatation?
I was using the overall buoyancy setup i use with the Retra Maxi strobes. So it would be pretty negative with the Backscatters. The HF-1 float fully negated the weight of that strobe so the rig ended up much lighter. I loosened the arm and it would float around freely.
The Atom was still negative by 150grams or so and and the rig was noticably unbalanced. I will print a second float for the 2nd HF-1 and do another dive with the balanced setup.
I dove today with two HF-1s and the floats. They both worked well and retained integrity.
The overall rig was basically neutral and just slightly negative. However, with the two strobes extended forward of the port, the system wanted to roll backwards. With neutral floats and my ULCS float arms, the extended arms were a bit too floaty and torqued upward. With the strobes in-line with the housing it was balanced. I am going to make another change and make the floats a little smaller and less buoyant by about 25 grams each. I think that will result in just a little better balance.
Edited by Dave_Hicks
The Backscatter HF-1 Float is done. I've done several test dives on a pair of floats and they worked well. I am making another pair now that drops about 20 more grams of buoyancy.
This morning I designed the Atom float and sized them to provide 140 grams of buoyancy against the 160 grams weight of the Atom's in water. Leaving it 20 grams negative. The draft print came out great. I trimmed it bit more after the draft to fine tune the target buoyancy.
Atom Float +140 grams:
Have you considered spraying these with a sealing spray or waterproof finish?
I'll be very surprised if these don't leak over time as FDM printing isn't watertight, and the water pressure will find the pathways.
This assumption what 3d printed objects can't be watertight is disproven by the fact that I and others have made very successful watertight and pressure resistant objects. It is completely possible. No sealants or post processing is needed if you design and print the objects with the right recipe of material and parameters. Some of my macro port floats have been used for two years and over a hundred dives without failing. Often to depths beyond 30 meters.
More recently I am also diving with 3D printed port extension rings on my Nauticam housing. An integral component of housing's pressure vessel. They are completely waterproof and incredibly strong. ABS, ASA, or PETG filament right off the printer with no additional sealants.
Actually, sealants are a false solution as they DO fail, fade, and flake off. I experimented with epoxy resin before I learned how to print properly, and I did have leaks when the sealants cracked and failed.
I tested the "final" versions of the HF-1 and Atom strobe floats. They worked great and were easy to use without getting in the way.
I have a couple of dive-tested pre-final HF-1 floats if anyone want them. Message me if you want them for the cost of shipping.
i think i am far away on the other side of the world... are the print file available anywhere?
