Preview of the MFO-2 - Now called MFO-3
Featured Replies
I have now had Marelux 60 lens for about a month. I bought it for the specification of focusing well beyond the ~1 meter MFO-3 limit. The MFO-3 had been on my radar since the announcement. I was about to buy the MFO-3 about the time Phil wrote his blurb on the Marelux lens here on Wetpixels. I then looked on the Marelux site and contacted them to verify this specification which they did so I ordered it right away as I have one use case here in AK and it was due about 1 month after the solstice: the arrival of Pink Salmon in an intertidal creek near where I live. For a few days sea lice stay attached and I wanted to shoot them with a normal focal length.
We had a lot of rain from several storm systems during July. When it cleared up the residents along the creek told me they had been there for just a couple of days and it looked like the whole run entered at once likely triggered by all the rain. So I had my chance. This was also my first salmon shoot with the new Maxi strobe which I had pre-ordered way back when. See pix. One is square crop of a D800 image showing the flank of a Pink Salmon. Note the bug near the center. I looked at it at 300% and did a frame grab which is attached as well. This is an early stage of a sea louse. Prior to the big rain I attempted shooting it in the nearby lake on a sunny day. Although it looks calm there was enough of a swell to cause the algae I was shooting to sway so those pix had to be binned.
The other pix show how I used the lens on a Seacam housing. I used a Nauticam bayonet adapter and bayonet holder on a Saga port. I bought a cheap 77mm thread petal lens shade that has a plastic thread so is semi-disposable. I would avoid using metal-metal threads in seawater. The rubber shade used on my first trial (in pic) did vignette.
Edited by Tom Kline
  • Replies 114
  • Views 22.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Alex_Mustard
    Alex_Mustard
    No idea. The normal rule in underwater photography is think of the maximum amount you can possibly justify or afford and then double it!
  • Alex_Mustard
    Alex_Mustard
    A point worth raising is that it is difficult to do really precise test shots with and without the MFO-2.  I just wanted to highlight this issue – as surely many with and without shots will be shared
  • Walt Stearns
    Walt Stearns
    I have just started using a Nauticam MFO-3 mounted with a flip adapter with a Nikon Z8 and Nikon Z 105mm f/2.8 VR S Macro Lens and found that it worked surprisingly well.   The best testament to just
Posted Images
15 hours ago, Phil Rudin said:
Both the Nauticam and Marelux lenses have a 0.9X max magnification and on full frame are generally assumed to be suitable for 90mm, 100mm and 105mm macro lenses. So AOV's of 27 degrees, 24 degrees and 23 degrees. With the MFO-3 and MV-60 in place the result is an AOV of around 47 degrees+/-, 40 degrees and 38 degrees. Nauticam states it was tested with the Nikon Z 105mm macro and has a working distance of 0-1500mm or 59 inches. The Marelux MV-60 was tested using a 100mm macro so 24 degrees and 40 degrees with a working distance of 0-infinity, spec's from each websites.
I am sure many will say that shooting beyond 59 inches/1500mm is a waist of time however what shooting to infinity points out is the large difference in lens design between these two lenses. My guess is that having a flat front element allows the MV-60 to focus to infinity while the curved front element of the MFO-3 restricts working distance. This may also explain a difference in AF speed although this is purely speculative. Different camera systems have a wide verity of AF choices and to have a relevant comparison you would need to be using the same system with the same AF setting I would think.
The max magnification varies depending of focal length for the MFO3 with the Sony 90mm reporting 0.8x from the port charts. All lenses focus between 0 and about 1500mm with the MFO3 added . The stated design from Nauticam is that the MFO3 corrects for having a flat port so has better corners than what a 50/60mm macro would have through a flat port and also shifts the the focus range of the so that in common 0.5x to min magnification range corresponds to the lens focusing to infinity and the fact the lens is out in the range where AF is fast and snappy on the bare lens, so AF improves. In my case with the olympus 60mm macro my limit is 0.5x - but for what I use the MFO3 for - it's a non issue.
I've certainly found my MFO3 to be snappy when focusing once the lens racks out to the focal range needed after I first attach it, beyond that I don't even think about AF, it just snaps on. Whether or not the corners improve - I have not done any sort of detailed comparison, I'm just very happy with what it does.
In terms of sharpness crushing - a lot of people are using the MFO2 now it seems and I don't recall anyone complaining about sharpness. These lenses are being used with Canon/Nikon/Sony top line macro lenses which are as a rule no slouch optically, seems to me it would be a hard ask for a different supplementary lens to claim to be crushing relative sharpness performance when using the add-on lens unless Nauticam is destroying it. As good as the bare lens or a little better - sure seems quite plausible. I haven’t used the Marelux version so don't know how it performs but have no reason to doubt it produces top notch images.
Needs someone to spend some pool or test tank time shooting resolution targets to put the question to bed. Me personally - I'd rather go diving - but would certainly review the results with interest if someone was keen enough to produce some images to compare. Any volunteers?😅
  • 1 month later...
This is a comparison between the Nauticam and the Marelux being used by Tom Kline and others. AOV range, weight both in and out of water, and focus range are some of the differences as well as lens design.
14 hours ago, Chris Ross said:
Update - I was told it's revised glass, they don't seem to be claiming any improvement for it.
Interesting. I’ve had one on order since June. I heard they had quality issues that delayed delivery. Maybe they had to switch to a new glass supply?
Where are the Nauticam optics manufactured?
I could be mistaken, but it appears to me the MFO-3ii now has some sort of built-in lens shade/protector
The MFO-3 has a bulbous/curved front glass which was not designed for adding filters like ND's .They have an optional push on filter holder for an additional $50.00 plus for version I. I suspect this may now be built into the lens on V II. This is one of several differences for the Marelux MV60 which already has flatter front glass and a common 77mm thread size for a verity of filter types.including yellow for Flora.
Edited by Phil Rudin
If that is in fact an actual picture of the front of the “new” MFO-3 II, it does not look any different than the original MFO-3. However, if Nauticam were to change something on the II version, I would think they would add a threaded portion to the front like the MV-60 instead of that push on M82 FILTER HOLDER they offer for the MFO-3 instead of that redicules . that Phil mentioned is doubles as a protective guard for the front of the MFO-3. While it is treaded for 82mm size filter, they are not cheap (listed at $57 USD) and made of anodized aluminum that will instantly show where it made contact with a rock, coral, or anything else that is really hard that it is bumped into.
Edited by Walt Stearns
Mainland China / Shenzhen, if I'm not mistaken?
Thanks.
Edited by ACHiPo
The MFO-3 and MFO-3II are optically identical. The glass supplier changed so the nomenclature changed to differentiate for any repair/glass replacement purposes in the future. The dimensions are a few MM different but that is it
As I look more at the photo from the nauticam website that I posted, I think I see now that the objective lens is right at the front of the lens, and what I thought was a recessed lens is just due to the limited reflection off the front glass. Sorry for my error.
