GoPro Mission 1 Series
Featured Replies
2 hours ago, Elvandar said:
Found two reel with the new adaptor for the mission 1 case, inon is testing it with the ZD lens
https://www.instagram.com/reel/DZCh17ZDxvX/?igsh=eHBsa2Y4cnAya2hm
https://www.instagram.com/reel/DZKr4TsvwtL/?igsh=MXhnOXZ6ajM1Z3h0ZA==
To be precise, this is actually Taiwanese OEM manufacturer Howshot (main distribution channel Divervision ) showing that their adaptor works with the Inon UFL-GR140 lens on the housing.
Edited by bghazzal
  • 3 weeks later...
  • Replies 96
  • Views 17.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Davide DB
    Davide DB
    I agree with you that in this era of hardcore DIY, there will be someone printing gears and extensions for ports already on the market. I can already hear the sound of @Dave_Hicks printer 😃 Maybe ther
  • Elvandar
    Elvandar
    Found two reel with the new adaptor for the mission 1 case, inon is testing it with the ZD lens https://www.instagram.com/reel/DZCh17ZDxvX/?igsh=eHBsa2Y4cnAya2hm https://www.instagram.com/reel/DZKr
  • Nikolausz
    Nikolausz
    I absolutely agree with your analysis and I came to a similar conclusion. Due to the crop factor, we can forget the ILS version for wide angle (but the mission 1 pro will be interesting). I played a b
Posted Images
Another update for the mission one adapter for inon lens
Video
Edited by Elvandar
I got a Rikroll video for some reason on the link 😂
1 minute ago, Davide DB said:
Are you sure? 🤣
Changed the link, I don't know from where I pasted it 😂
But on your response, is still the mistake 🤌
Hello. I follow Sean Elliot's YT channel. Full lenght review this weekend, I suppose he's always reliable
He says "The Mission 1 Pro has a lot to love but sadly the way they have set the focus for a more cinematic look above water has made it VERY difficult to use undewater. Everyone knows there is an issue with minimum focus but you cant fix that with lenses. The BIG issue is that it also has a very short maximum focus and once you put any of the current wide angle lenses on it makes it unuseable past a few metres and I have tried the AOI, Inon and Weefine." I'm speechless...
Edited by Gmsalterego
It is quite a problem. Action cameras have fixed focus and everything works perfectly because the sensor is tiny, but even with a one-inch sensor, issues start to appear and so manufacturers make compromises. The matter reminds me of what happened with the old Insta with the one-inch sensor years ago. YouTubers noticed that they couldn't take selfies at arm's length because with the one-inch sensor, the minimum focus distance had been set to about one meter. To solve the problem, someone even came up with the idea of adding a small lens attachment to allow focusing at less than one meter. Probably the design of the new GoPro lens creates problems for the wet lenses currently on the market, and who knows, maybe they will have to be redesigned specifically for this camera. Strange that the same thing doesn't happen with the old one-inch Insta360 too or maybe it's there but nobody notice it.
Here the old video:
Found the same reel, it's not a small problem for lens owners who wanted to upgrade the GoPro path, I'll paste the link for it for who want to see
Mission 1 lens test
I'm even happier now I choosed the L10 upgrade
In my opinion, when the 1 inch sensors were introduced, they should have also implemented an AF system into these small cameras. I wouldn't call them action cameras but small content creator cameras. Most of them are not used for sport anyway.
But at that point you have more compact capable cameras expressly made for content creators with proper af, microphone and I/Os
That's catch 22
I will stick to my small sensor GoPro
Edited by Nikolausz
I got the Mission 1 Pro and the Inon lenses GR140 Pro and G165II.
As ZD connection, I went for the Howshot because, as we know, Inon didn't release yet its own front mask for the Mission 1. But the one from Howshot is well build and it will serve the purpose well, at least until Inon will produce its own, later in the year.
In two weeks, I am going to test the different setups but from what I've understood, the Mission 1 Pro seems to be very good without wet lenses, for the general shooting with underwater focus going from 50cm to 6m, which is the farthest you can go underwater anyway.
Instead, the wide wet lens bring the focus closer to 10cm stopping at around 2m, maybe 2,5m, which it could create a nice cinematic look also underwater, when swimming close to reef and/or fishes.
Since I am not into macro but close-up is the max I would go, I got the G165II but it seems I am the only one because I couldn't find anybody giving me a feedback on this lens. So I just have to wait two more weeks and see how this lens will perform with the Mission 1. I would expect to be somewhere in between a close-up and macro, considering what I heard about the Mission 1, so far.
I agree that in the hands of a professional it can get interesting effects, but in general having a wide lens and not being able to focus beyond 2.5 meters is a big problem. Inon and AOI will be forced to redesign their lenses, or this Mission 1 will be forgotten in a short time. The swan song of a company on the brink of despair. In the coming months we will see if these companies want to invest money in this project.
The situation with close-up lenses is interesting. I have an AOI UCL-03 that I used for a project. Looking back, I should have bought the Inon, which is much more flexible. The AOI has a focus range of 4 to 8 cm, while the Inon has 10 to 25 cm. It is much more versatile. If the reduction of the focus range also applies to these lenses, my AOI becomes unusable. Inon, who knows. With the GoPro 11 I had to use a brush where I had marked the focus range with colored tape. I used it for time-lapses of gastropod mollusks.
Ive spend one week in Koh Tao and another week in Bangkok where i was able to do some tests to the Mission 1 Pro & GP13 and in my opinion the M1PRO has strong limitations without proper underwater lens to get some focus back on.
Gp-log2 is amazing for color grading, so much flexibility but the lack of focus is really challenging.
Dynamic Range and low light in M1PRO is way better than Gp13 and with right distance is possible to get great scenery images, the weak point of GP13.
I want to like the M1PRO but unless some 3rd party manufacturer offer correction wet lens specific for focus distance its waste of time in underwater use.
This looks like quite a close-up, if not even a macro. Did you use a wet lens or just the camera without any attached lens?
3 hours ago, Nando Diver said:
Just the camera..no lens
The GP13 at same distance is fine..
To be honest, I expect worst at that close distance. I will see with a close-up lens how it will be.
Ive optimized the GP13 with Gopro labs FW + 2 dive lights (5000Lumens) and AOI wide angle lens, it works very well between 10cm and 50cm.
The Mission 1 pro dynamic range is capable of doing much better than the GP13 like ambient with or without natural light, but M1PRO has more like cinema softness image that dont work well underwater.
My advice, take a backup camera...the GR140 will help but will be far from perfect..
Also any other video mode outside of gplog2 will be waste of time in underwater Mode, increase the resolution to 300Mbps using gopro labs FW, Max ISO 800..
