GoPro Mission 1 Series
Featured Replies
I am not sure I've understood the purpose of the blurry adjustment in post.
Can you post also the clip with unadjusted blurry?
16 hours ago, Nando Diver said:
Heres a 240fps clip
Notice the focus diference between the fish school that are closed to the camera (in focus) to the others further away (not in focus)
Ive adjust the blurry in davinci to be more noticeable in the clip.
https://www.youtube.com/watch?v=6jHAZiEgX94
  • Replies 96
  • Views 17.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Davide DB
    Davide DB
    I agree with you that in this era of hardcore DIY, there will be someone printing gears and extensions for ports already on the market. I can already hear the sound of @Dave_Hicks printer 😃 Maybe ther
  • Elvandar
    Elvandar
    Found two reel with the new adaptor for the mission 1 case, inon is testing it with the ZD lens https://www.instagram.com/reel/DZCh17ZDxvX/?igsh=eHBsa2Y4cnAya2hm https://www.instagram.com/reel/DZKr
  • Nikolausz
    Nikolausz
    I absolutely agree with your analysis and I came to a similar conclusion. Due to the crop factor, we can forget the ILS version for wide angle (but the mission 1 pro will be interesting). I played a b
Posted Images
I have the GR140Pro and the G165II and my understanding, so far, is:
  • No lens - focus between 50cm to 6m - perfect for general underwater landscape
  • GR140 - focus between 15cm to 2,5m - perfect for walls/reefs wide sceneries
  • G165II - no reference available but I expect something between close-up and macro. The question is how deep is its DOF. I hope for something like 10-60cm, anything less would not be for me.
I will test the three configurations and see but in principle I like the idea of having some light softness outside the focus range because it directs the view on the subject. Maybe because I come from photography background, I have never been a fan of infinity focus, on the contrary, I always considered it as a defect.
I believe the M1 has to be used differently than other action cams, paying more attention to focusing and framing, just like in photography, but that it not necessary a negative thing and I can understand that for someone it could be a problem. It is not easy to change the way we are used to do things.
Of course, for now these are all theories, until I bring all below the surface and test them. One more week to go.
The Mission 1 pro dynamic range is capable of doing much better than the GP13 like ambient with or without natural light, but M1PRO has more like cinema softness image that dont work well underwater.
My advice, take a backup camera...the GR140 will help but will be far from perfect..
Also any other video mode outside of gplog2 will be waste of time in underwater Mode, increase the resolution to 300Mbps using gopro labs FW, Max ISO 800..
Edited by BeppePADI
Ive sent you link with original file..see for yourself
8 hours ago, Davide DB said:
Out of curiosity: what's the meaning of shooting @240fps?
you can capture details underwater that are impossible to see with naked eye.
You got a camera that is able to do high frame rates and you dont test it.
Thank you, I quickly color graded in Premiere Pro and without blurring it, I see slight focus different between the front fishes and the ones in the back, but it is very gradual and I do not find it an issue. On the contrary, I think it makes the image quite appealing.
Edited by BeppePADI
With GP13 i was filming much closer to the subject due focus distance, on the Mission 1 pro in certain conditions it might work, but theres always the temptation to get closer and closer to the subject.
  • 3 weeks later...
Bayonet Mount QR2 Adapter Mission 1 Pro from Glowdive
INON UFL G140SD (minimal focus 15cm)
Backscatter Sharp pro
AOI UWL 03
AOI UWL 03P RO
AOI UWL 03 II
AOI UWL 03 II PRO (minimal focus 15cm
AOI UCL-03
Edited by Nando Diver
How is the M1 Pro for photography in the 60 metre housing? (when shooting things at about 2-3 metres range without any accessory lenses). Reason for asking is am wondering whether it is going to be an improvement over the Hero13 for photogrammetry work?
  • 1 month later...
Stunning video & colors using Mission 1 PRO ILS
this guy makes crazy filming..
  • 1 month later...
Mission 1 Pro vs The Seals: Did Inon Faceplate Fix The Focus?
Yes it did - for close subjects. Everything further away is blurry. I think the problem with Mission1 (minimum focus distance) is unfixable. Yes you can slap wet lens in front of it but then it acts as a macro lens - you get your working distance but that's it. So yes you can plan your shoot, bring lenses required and get great footage. But by no means is this Mission1 camera all purpose versatile no settings no thinking required action cam for underwater. For that one needs to look elsewhere.
  • 2 weeks later...
Anyone taking the Mission 1 pro for holidays (avoid it) there a color shift bug affecting the camera..
I have 300gb of Maldives filming ruined due the color shifting... it affects all color modes.
https://youtu.be/Ml0JCqbTbZs
A recent regressionbug or a issue you havent find before?
Edited by Gmsalterego
my last filming/diving before the Maldives was September, I check the videos and the issue is not present with old firmware, the bug came with latest firmware from v4.01.70, Oct 13, 2026
The reply I got from Gopro labs, there's also another diver that report the same...
There is a small bug in BITR that might be effecting color compression. Try using bitrate MAX with *BITR=0
Try within BITR, on M1P (not ILS) there is was a difference in the chroma encoding. This difference only happens with BITR. The chroma encoding error will be addressed in the next release.
  • 2 weeks later...
New firmware for Mission 1 & Pro & ILS (this will fix the color shift underwater)
V4.10.70 - Nov 18, 2026
  • Added USB connection controls: u0 - Allow, u1 - Ask, u2 - Never
  • Fixed NR01 to turn off more noise reduction from boot
  • Fixed QR Code scanning in the new photo mode
  • Fixed Histogram in the new photo mode
  • Fixed color issues with BITR captures.
  • latest mainline features on Labs.
  • ILS only, improved Anamorphic Lens stabilization.
Labs test From digital camera world to the Mission 1 PRO ILS, they use as reference the Canon PowerShot V1, Nikon ZR & Panasonic GH7
Source : https://www.digitalcameraworld.com/cameras/action-cameras/i-lab-tested-the-gopro-mission-1-pro-ils-and-was-shocked-by-its-results
In theory, a small sensor with a high resolution should be especially prone to image noise. Each pixel has to be incredibly small in order to pack 50 million of them onto a 1-inch sensor, and their small size makes each pixel less light-sensitive and in turn more susceptible to generating noise. But the Mission 1 Pro ILS throws this conventional wisdom right out the window, as not only does it product stills with noticeably less noise than equivalent shots from the far less pixel-packed Canon and Panasonic cameras, it comes close to equalling the image clarity of the full-frame Nikon ZR! If GoPro had enabled even higher ISO sensitivities, chances are the Mission 1 Pro ILS's signal to noise score would deteriorate rapidly - a 1-inch sensor camera does have its limits - but this is nonetheless a remarkable performance.
Though the camera can shoot stills in Raw, its still image quality settings are nowhere near as granular as you'll find in a typical mirrorless interchangeable lens camera, so it's possible some dynamic range boost or noise reduction may be baked into each raw file
Applying baked-in noise reduction or dynamic-range enhancement to RAW files is an interesting concept ...
Apparently the Underwater Mode from Mission 1 pro is managed by the Gopro Image Tuning team according to Gopro labs source, and some of the underwater labs settings of GP13 like Dive and probably (just a guess) WBDV=1 + WARM=x + COOL=x was used to create the underwater profile..
Until today the Gopro 13 with labs firmware flat + Wide + dive=1 + WBLK + 190Mbps is perfect tuned for underwater + color correction with gp-tune...
On the mission 1 Pro Ive run into some color issues in Underwater Mode, with very bluish color using dive lights...
Upon request on GoPro Labs, the Developer create a Labs Test firmware and Dive WBLK preset specifically for the scuba divers, now the Mission 1 Pro has is own Dive Mode without color gain (red, blue,green)
I only have chance to test it next weekend, but if anyone want to try it here is the firmware link & Dive mode configuration
https://www.dropbox.com/scl/fi/14lcmfw959doqkx53sdwu/LABS_M1PRO_04_10_71.zip?rlkey=k8wg2jq06wau1ng1dyxymt3hj&dl=1
https://gopro.github.io/labs/control/divemodem1/
GitHub
No image preview
MISSION 1 PRO - v4.10.70 Firmware underwater Mode color i...
Previously ive used gp-log2 but the color lack some vibrant/punch colors after color grading Today tested the v4.10.70 Firmware in Underwater mode & flat color and there is too much blueish especia...
Settings to test:
Preset DIVE WBLK
16:9 4K 60
Balanced or Sport
Wide / Autoboost
10bit / max / HLG OFF
Color flat / white balance auto / iso 25-800
Sharpness Medium / Denoise Low
Preset DIVE WBLK
16:9 4K 60
balanced or sport
Wide / Autoboost
Color GP-LOG2 / white balance auto / iso 25-800
Preset DIVE WBLK
16:9 4K 60
Color profile Balanced or sport
Wide / Autoboost
Color flat or gplog2 / Native white balance / iso 25-800
try to use white ColorChecker card if you shoot Native white balance
