GoPro Mission 1 Series
Featured Replies
This is the best insight video ive seen about Gopro M1,M1PRO, M1PRO ILS
Edited by Nando Diver
  • Replies 96
  • Views 17.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Davide DB
    Davide DB
    I agree with you that in this era of hardcore DIY, there will be someone printing gears and extensions for ports already on the market. I can already hear the sound of @Dave_Hicks printer 😃 Maybe ther
  • Elvandar
    Elvandar
    Found two reel with the new adaptor for the mission 1 case, inon is testing it with the ZD lens https://www.instagram.com/reel/DZCh17ZDxvX/?igsh=eHBsa2Y4cnAya2hm https://www.instagram.com/reel/DZKr
  • Nikolausz
    Nikolausz
    I absolutely agree with your analysis and I came to a similar conclusion. Due to the crop factor, we can forget the ILS version for wide angle (but the mission 1 pro will be interesting). I played a b
Posted Images
David Newman from Gopro Labs said in Las vegas that the Mission 1 cameras with NO AIRFLOW (sitting on the desk) running 8K60 or 4K120 will overheat after 40 minutes.
In real world use (with airflow) use at 77F or 25C (Gopro testing) it will run until the battery drains out
From the DC RAINMAKER VIDEO :
Lens WIDE 16-24mm (8K60 or 4K240)
Lens Linear 22-27mm (8K60 or 4K240)
Superview 16mm (Limited 8K30 or 4K240)
Some of the settings i suspect they are coming from Gopro labs firmware implemented in the stock firmware, like DIVE MODE for refraction of the water to avoid corner distortion & STABILIZATION algoritmth for underwater
NEW SETTINGS or RENAMED
8K Open Gate 4:3 (previous called 8:7)
Added Mode DIVE MODE
Image Tunning stabilization (balanced, sport, face, Underwater )
Gopro labs support ( example : Bitrate up to 300Mbps, True 24fps, 100GB per file, Histogram, On-screen spirit Level )
Added Mode Low-light dedicated Mode (Limited 4K60 16:9 or 4:3)
Added Mode Subject Tracking
Added Mode Slow-Motion
Added Mode Vlog
Added Mode looping
Added Mode Sport POV
Added Mode Video
Added Mode Mission pro
Added Mode Photo
New Shutter Speed (Auto, Fixed or Range)
New ISO settings (Auto, Fixed or Range)
New Zoom option up to 4.0X
New Anti-flicker setting
New back screen information available (EV, WB, ISO, Shutter speed)
Motion Blur (Adaptive, cinematic, & other )
Bit rate up to 240Mbps (Max, High & Standard)
5X color modes (Gp Log2, cinematic, flat, Natural & Vibrant)
Apply one specific setting to all Modes
New Photo Mode 50M (standart or RAW)
New enduro battery charge in 20 minutes (see chart for how long batteries last)
Heres a great Interview by CineD regarding the M1,M1PRO & M1PRO ILS
All the Geeky and technical stuff and which market are this camera for, really worth to watch.
Dive house for M1PRO series
Now with 2 mount options, vertical or horizontal
The Mission 1 series according to the developer will be so good underwater that the Dive=1 feature from Gopro labs is no longer required..
But the option to lock white balance will be available..
On 4/14/2026 at 7:59 PM, Davide DB said:
ILS model with the mighty Pana 8mm fisheye.
You need a housing and of course electronic contacts. I don't see any formal M43 mount Alliance membership so IMHO for the moment DOA for underwater use.
Not necessarily DOA for underwater use as there are many non-electronic lenses that can actually be used underwater (e.g. Laowa or TTArtisan) in the macro or wide angle world. But the bigger problem I see is since no manufacturer does focus/zoom/aperture ring for those lenses, using those lenses will require DIY solutions such as 3D printed gears and ultimately that means unfortunately that there is a low probability that as a manufacturer makes a housing for such system as it would requires them to develop also lens gears. There has been a few camera body for studios (e.g Lumix BS1H, BGH1) that could have had their own housing from Nauticam with an MFT established port chart and it never happened for some reasons.
Edited by eocean-eu
Maybe there will even be some Chinese manufacturer already working on something industrial.
But is it worth it? And at what cost?
We are entering luxury Weefine/AOI housing territory. Honestly, it seems like overkill to me. You end up with the price of a real Mirrorless kit but with only disadvantages: fixed focus, everything automatic. Look at the photos @bvanant takes with his OM and AOI housing 😉
Besides, I don't see all these lenses being suitable underwater.
The GPM1 ILS has a crop factor between 2.7 and 3. Even the Pana fisheye would probably have a narrower AOW than the Canon 8-15 and 2x teleconverter that everyone is talking about here.
Other lenses are even worse. A Pana 12mm becomes at least a 30mm. Good luck! Maybe close focus and macro... MF of course.
Then again, I would be curious to see some interesting crazy project, but what I meant is that we are moving away from the target point-and-shoot customer. And if I have to deal with a pricey rig as big as a mirrorless with no economic or usability advantages, I don't see the point.
Happy to be proven wrong.
On the other hand, for underwater use, the iterations of the classic GoPro are very interesting.
This ILS might make sense for fun use in land shots and for use as a crash cam in cinema.
Ciao
Ciao
I absolutely agree with your analysis and I came to a similar conclusion. Due to the crop factor, we can forget the ILS version for wide angle (but the mission 1 pro will be interesting). I played a bit with the idea of building a compact macro system around the ILS version, but honestly, it makes more sense to spend the same money on an MFT camera with a properly communicating macro lens with AF. Not to mention that according some rumours, the new Sony RX100 camera with 1 inch sensor is around the corner. Probably a safer bet to build an underwater camera system around it.
  • 3 weeks later...
Also very interesting discussion about Color Options for gopro log
Oficial LUT gopro
Thatcher DTCL
Xtremestuff
Python Lut
  • Author
Some underwater shots from the Mission 1 - seems pretty good for no lights.
Also looks like it is available for Pre-order including the dive case. Unfortunately it looks like the dive case has the same mediocre button on top, even though they made the one on the camera better. This top button has been the one reason I have looked at other housings, but never been willing to pay 20x for a housing simply for a better 'shutter' button. Hopefully the new one still works better! It is unclear from the post referenced above whether the user was just using the camera without housing to 20m (and liked the buttons) or was using it in the housing. Eagerly awaiting more underwater imagery from this camera.
The gopro labs list is out for the M1PRO
Dive mode now is standart
Low light mode is standart
Preset names with labs commands is supported, like in GP13, this allowed to have several presets with gopro labs features permanent in that specific preset name, like WBLK.
Wide color gamut is now standart
White balance lock is supported
https://gopro.github.io/labs/
A critical problem, in my opinion, is the minimal focus distance with Mission 1. It is way longer than in the case of the black series due to the larger sensor. It will be OK for reef scapes but CFWA pictures will be not sharp. As moving as close as possible, especially in case of lower visibility, it is important for underwater videography to use an additional correction lens. I'm not sure if existing lenses (non or AOI) were compatible or not.
Slow in getting a case...haha...
Hope it will be back in stock soon...
Seen the video with the inon zd lens... Let's seee
On the Mission 1 pro has being added range to the already existent Auto and fixed
Shutter Range :
1/120 - 1/7680
1/240 - 1/7680
1/360 - 1/7680
Iso Range:
25-100
25-200
25-400
25-800
25-1600
25-3200
25-6400
And now is visible Shutter -iso - ev comp - wb in the top of the screen
