List of Underwater Monitors
Featured Replies
OM System
The WED-7 Pro has definitely a flip option that can be assigned to a F button.
  • The comment on the EWML is true when someone is not using the relay but it is also handy to be able to flip the monitor for HDMI cable management. Mine is by flipped but I have to press the function button to flip the screen after power on.
  • WED-5 Pro has a port to upload LUTs. I am trying to find the manual online.
  • 5 weeks later...
Hello everyone.
You can find the manual for the Weefine WED 5pro here: https://www.weefine.com/static/upload/file/20250903/1756894011377368.pdf
I've had mine since last week. It's a light and fine little monitor. The monitor is very bright and I ran it non-stop for 1.5 hours today with a 5000mAh battery at the brightest setting. There is now also a 6000mAh battery available in this size (but without a USB-C charging port). so battery life is superb.
The mounting ball can be mounted at the top or bottom, and the sun visor can also be rotated. In addition, the image can also be rotated in the monitor. This can also be programmed to a short key.
If you have any further questions, just let me know.
  • Author
2 hours ago, samuel.heim said:
Hello everyone.
Do you have a photo of your setup?
If you mount the monitor centrally on the camera.l, won't the gigantic HDMI connector coming out on the left hit the left floating arm?
It doesn't look possible to tilt the monitor without hitting or moving the arm.
I don't know what kind of float arms you use, but the cable routing is actually a little different, and depending on how the monitor is mounted, the cable can get in the way (in my setup). I mainly use the monitor behind the camera and not above it.
This is the best option for me, and I can move the flash arms freely. It also works well when transporting with a lanyard.
Incidentally, the cable is much stiffer, nothing like the previous model. It's very difficult to bend. I hope it lasts longer now.2.png
Here are a few other examples. It sometimes lightly touches the float arm.7.png
  • Author
Thanks for the photos,
I think that in my current configuration that cable would a major PITA.
When i was young 😉 I used to have the monitor positioned as you. Now with my fading eyesight I put it on top forward and the connector/cable would hit the left floating arm.
I just arrived to this thread by curiosity, I don't know if it's possible what I'm going to suggest. Just wondering while my new housing and camera arrives. As long as Canon R6 mkii have connection with the mobile phone with its own app where you can control almost all the camera. Has anyone tried to put a mobile phone into a housing and connect to the camera while underwater ?
I already have a Divevolk housing for mobile phone. I know it's going to be a very big rig, but is it technically possible ?
You need to make an antenna, which is very possible to DIY. I've considered it but the app for my camera is rather laggy.
Divevolk has one: https://www.divevolkdiving.com/products/divevolk-sealink-contact-type-underwater-wifi-signal-transmitter
I've had bad experiences with the canon app so I haven't bothered getting it.
Thank you very much for the tips, I didn't realized that I would need an extra accessory, I would spend that 200 euros if the result was guaranteed, but if I have to face lags and other issues I won't do it. I don't know what do I prefer, install a 45º Inon viewfinder in my new Isotta housing or a monitor.
  • Author
15 minutes ago, Grantmac said:
try this:
https://www.paulillsley.com/GoPro_Underwater_Wi-Fi_Cable_Setup/
I'd probably encapsulate the ends in epoxy but for a test they can probably just be left bare. Definitely test your particular camera's app above water to see if the function is useable though.
I used something like this on my GoPro 11 in a meter of water... but I was watching trouts from a river's Bank 😁
Anyway it works but it mainly depends on the remote app capabilities. BTW nowadays abproper monitor costs less than 1000 euro.
  • 4 weeks later...
On 5/20/2025 at 6:27 PM, Davide DB said:
Please help me correct and complete it.
Thanks Davide, for the amazing compilation!
Do you mind adding a column to show the monitors resolution.
The nits values are nice but an important information might also, if they do 720HD, 1080HD or even 4K.
  • 8 months later...
On 11/7/2025 at 10:53 PM, Davide DB said:
Yes,
I'm a bit in hurry this period. I promised to Romik to add another column. I will do.
Keep in account that 99% are 1080p panels that accept 4K input signal.
Many thanks for this great thread - it is very helpful, hopefully you will get the chance to update the tables sometime too.
BTW have any new monitors been released that aren't on the table?
Based on the table specs I am considering either the Fotocore MR5.5 or the MR6. The main difference apart from the slight size difference is that the MR5.5 comes with a heap of buttons on the monitor - any opinions as to whether the buttons on the monitor are a help or just something extra to fail?
Having setting custom options other than on/off on monitors is to me helpful.
For example, a feature that is available on the camera display might not be transferred through the HDMI cable to the monitor or might not be available on the camera but available on the monitor and therefore it may be interesting to be able to activate it while diving. For example:
  • Nikon have their zoom function on the screen but not on the monitor . I use the one on the monitor through a button
  • Many camera can not revert display underwater which would be useful when using a lens reverting the picture (e.g. EMWL without relay lens). I use the one on the monitor through a button.
  • Author
AFAIK the list is updated and there aren't new monitors out there.
I have not updated the table because further details would require the user manual of each monitor and I only found some of them.
IMHO watch out for the models you mentioned they weigh a really lot. Personally I think that the weight of the monitor in the water is a fundamental parameter.
As other memebers here I chose the Weefine wed-5 pro. IMHO has the best features/price ratio.
OK Cheers! My only concern with the Weefine is battery life so I will do some more research on that.
As I mentioned here I got largely over 2 hours of continuous runtime with the Weefine WED-5 Pro HD with the monitor at 30% display brightness.
This is in 26° water with a new 21700 battery, at 1080p HDMI output.
Official specs give 90 minutes, but I suspect this is at a higher brightness. At 3200 nits, it's very bright and 30% was fine for Okinawan sunshine in the shallows.
cheers
Edited by bghazzal
cheers
OK it might be worth a try then. Hopefully 12degC water won't affect the battery life too much.
  • 4 weeks later...
Super helpful table - thanks for this!
I used to use the Weefine WED-7 Pro, currently using the Fotocore MR5.5
I quite like the MR5.5, happy to give a short review of it if anyone is interested
  • Author
yes please.
I'm interested on a comparison too.
Also interested in your reasoning for going from the Weefine 7" to a smaller monitor, and also what your thoughts were on the Weefine 7"
