Jump to content
Preview of the Retra Maxi Strobe
Featured Replies
  • Author
9 hours ago, Chris Ross said:
I really think the fundamental problem is the response curve of the camera. That's not a fault rather that is how they are designed. The way around I think is to reduce the exposure. Easiest is lowering the ISO if possible, but looks like you at ISO 50 already, so maybe place a grey card on the wall and measure brightness off that or double the strobe's distance from the wall. You might run into problems at the low power end, but within the limitations of equipment you have available seems like this might be the best solution. You would need separate sets of measurements for the high and low powers.
Also as I understand it ISO 50 on the Z8 is extended ISO which is achieved by over exposing the image and pulling the exposure down which tends to blow highlights. Maybe for the Z8 base ISO might be a better option?
Some good ideas there. I might experiment with more range and a gray card.
  • Replies 121
  • Views 6.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Kiliii Yuyan
    Kiliii Yuyan
    Hi everyone, I just did a pretty extensive review of the Retra Maxis compared to several other top of the line strobes, using quantitative methods in a studio. I reckon it's a good counterpart to Dav
  • Dave_Hicks
    Dave_Hicks
    I updated the Power Level comparison, trying to find a better and cleaner way to visualize the range and alignment of power levels across the three strobes being compared. Feedback is welcome! (PREVI
  • Dave_Hicks
    Dave_Hicks
    Sharing are a few more wide-angle shots with the Maxi's. The water conditions around the PNW tend to be fairly particulate at the best of times, so I normally like to use reductions rings. The Maxi
Posted Images
On 1/28/2026 at 7:34 AM, Adventurer said:
Michi, if I read Dave & Killiii correctly than the Maxi is not what you are looking for and simply unable to deliver at these fps.
The Backscatter HF-1 is able to do it (I own and tested this) but there is brightness variation and quite a few blackout frames every few cycles in burst shooting.
The only strobe which is currently doing what you are looking for and which delivers zero light variations and zero blackout frames at high burst for more than 100 frames is the MARELUX Apollo III 2.0 in MTL Mode - which I also happen to own. I would subscribe to everything Henley Spiers wrote in his review:
DivePhotoGuide
First Impressions of the Marelux Apollo III 2.0 Strobe
Both my Backscatter HF-1 and Apollo deliver warmer light than my friends Seacam and old Retra, with a very simple fix I received from Hydronalin, Germany.
Hi, @Adventurer thx a lot for your personal advice and feedback! I guess for now the Apollo is the best product for me
@Dave_Hicks thx for all the effort so far - I appreciate this! it would be still nice if you can set your Camera to 10/15 frames per second and see what the Maxi does compared to the Backscatter a simillar decent power level! If this is not possible, just Let me know (i can Imagine how time consuming These Tests can be…)!
@Kiliii Yuyan thx for your great Test and all the effort - very interesting
I understand with a passing shark 5 shots per second or so is great but with for example a blenny eating algae from Seagrass and catching that exact Moment of the bite a high burst mode changes Everything…
Edited by Michi
  • Author
I took a break from shooting strobes at walls and went diving!
The assignment this time was CFWA with a 15mm fisheye lens and the Maxi's with a warming filter and reduction rings. Visibility was a pretty hazy silty 15ft / 5m so reduction rings were a big help.
Nikon Z8 w/8-15mm Fisheye lens, f11@1/30s iso400, Pair of Retra Maxi strobes with 4500k filters
Nikon Z8 w/8-15mm Fisheye lens, f11@1/40s iso640, Pair of Retra Maxi strobes with 4500k filters
Dive buddy Nirupam testing out a Nikon ZR / Ikelite setup.
Thanks for the great images and review. I was wondering if you could elaborate on stacking reduction rings with the warming filter. Are both of these the standard ones from Retra and can you put them in series? I also dive in meh visibility water and so was wondering how to lower the color temp while also reducing backscatter. Thanks!
  • Author
I made my own reduction rings that accommodate a diy filter. Message me if you want more details.
  • Author
I spent a little time today Re-Flashing some wall space with an aim to create more separation between the three strobes at the highest power levels. The tests so far have not shown a lot of gradation, possibly due to the short distance, low ISO, and small aperture.
I repositioned at 150cm from the wall, set ISO to the Z8 base of iso64, and aperture of f16. I only shot the Boost, +2, +1, and Full settings on the three strobes, as applicable. Photoshop luminance Mean and Point measures collected. I calculated a delta of the Mean measurements with the Maxi Boost mode as 100% and other results relative to that.
There is indeed a greater spread between the measured results using this method, supporting the idea that the previous settings were probably losing fidelity and flattening the results.
TLDR;
  • Maxi@Boost > HF-1@+2
  • Maxi@+4 (aka Full) > HF-1@Full
  • HF-1@Full > Atom@Full
Here are the results and visualization:
I think this supports also the 5% measurement and test + item variation delta I previously pointed out. Also a fresh from the factory strobe will be brighter than one that already has fired a few hundred shots. So no need in beating a dead horse and over-doing and over-interpreting these land tests.
What would be interesting though is a beam (1-1.5m) wall test submerged in water to see the different dome and reflector designs come into play.
  • Author
All of the strobes have fired at least 1000 times now, HF-1 tens of thousands at least. I won't be doing any static in water testing.
On 1/29/2026 at 2:55 AM, Chris Ross said:
If I am reading things correctly Killiii's test shows some interesting points.
First he tests at 8 FPS on the Apollo III in MTL at 12 = (max power) and it illuminates every frame and drops one stop in power by frame 8. It stabilises with constant brightness when power is reduced to 9 . The important thing to note that full power in MTL mode is about 1/2 the max output of the strobe. So it is one stop down from max power in regular manual mode.
The Retra Maxi goes close to the this when set to -4 power- it starts brighter and drops to lower than the the output from the Apollo after a few frames. I'm wondering if the test would be more informative if you set the Retra Maxi at a power to achieve the same light level as the Apollo III at the 9 setting? It should give a few more frames at that setting compared to what was achieved in the test.
The test then goes on to compare the Apollo III and Maxi at 6 FPS with a diffuser on the Apollo as it really needs one to get close on light quality. Settings are 12 and -6 respectively and the light output is the same by the light meter reading.
To me it seems any comparison should be at a setting where light output is constant and equal. If you want high speed shooting then only getting the strobe output for the first frame or two kind of defeats the purpose. Whether one strobe is at half power and the other at 1/4 is somewhat irrelevant, to get a true comparison you want the same amount of light falling on your subject.
I ran the test you're describing 2 years ago between the HF-1 and Apollo III (basically, normalized power output after the initial dimming period) to see what the max power each strobe could achieve in a continuous shooting scenario at 3fps, 6fps and 12fps was. Here's the results (also in the shared google spreadsheet that's pinned at the top of this forum). My results were that in actuality the HF-1 puts out more power at each frame rate than the Marelux Apollo 3 despite the latter marketing its MTL feature heavily. (I have no incentive to make this up -- I own the Marelux Apollo 3 and have been trying to sell my 2 units since.. 2 years ago :))
Strobe
GN @ 3fps
GN @ 6fps
GN @ 12fps
Backscatter HF-1
16
11
8.5
Backscatter MF-2
13
2.8
2.8
Supe D-Pro
13
10
8
Marelux Apollo 3
11
7.1
6.3
Ikelite DS230
11
0
0
Inon S-220
10
5.6
5
Sea & Sea YS-D3
9
4.5
4.5
Seacam 160D
Retra Pro Max
Hi Dreifish, I think your Apollo III units where not functioning OK or your test setup was faulty in some way. I cannot confirm the way you trashed that strobe, having now shot this and the HF-1 for two years. I bought the HF-1 because of your disruptive Excel sheet back in the days.
In fact my HF-1 does not deliver the power you claimed at high frame rates and does many blackout frames and light variation.
You may want to reach out to your dealer or Marelux to get your strobes replaced.
Hi @Adventurer , I believe you have Apollo III 2.0 strobes based on your previous posts, the data from @DreiFish mentions Apollo III, not Apollo III 2.0 - is this referring to the same model strobes?
I found the same thing using the Apollo strobes vs the Backscatter HF1s shooting blackwater back in March. Working in the desirable range of 2-4 frames a second shooting blackwater (you really don't need to shoot faster than that), I found the HF1 always gave me more light than the Apollo. Marelux suggested there might be something wrong with both of their strobes I was using.
Edited by Alex_Mustard
Matthew and I recorded this last week about the Maxi. Not much new here - we summarise a lot of what is in this thread. But we do show lots of photos taken with the Maxis and also video of us shooting with the strobes.
@Alex_Mustard Didn't you shoot Apollo S strobes, not Apollo III 2.0 in blackwater ?
From what I understand smaller sized Apollo S are supposed to be much weaker than HF-1.
I just recall you not finding the MTL mode when you had Apollo III 2.0 in the Red Sea with Oceanic Whitetips?
You must have gotten distracted by the lovely bouncing batteries, you were so enchanted about 😏
I shot the Apollo III for both oceanics in the Red Sea and blackwater in Anilao (see below). I shot the Apollo S during the day in Anilao.
That seems a bit different from what you said in the video. I actually stumbled across it again while trying to find Dr. Alex Mustard’s Marelux Apollo review.
It’s not easy to locate, because the review is kind of “hidden” under a subtle title and isn’t as heavily keyworded or clearly titled as the RETRA strobe episodes on The Underwater Photography Show.
As a regular viewer and big fan of the show, I’d like to suggest something: maybe you could give the Marelux “Apollo S” and “Apollo III (revisited)” strobes their own dedicated episode, so they’re covered as fairly and prominently as the Retras and Krakens—which have been episode headliners, sometimes with less overall content.
Anyway,...
Thanks to ChatGPT I was able to pull out a well formatted and still exact quote from the videos transcript.
on 17th March 2025, Alex_Mustard said into the camera:
[ .. ] One of the things we didn't talk about when I reviewed the Marelux IIIs on here previously was their MTL mode which is their fast shooting mode, and I did try that with the with the Marelux III on a Blackwater Dive one evening. And those evenings those Dives were really good Dives, so I think I shot something ridiculous like 830 photos across two blackwater dives using the highs speed shooting. Mathew Sullivan: "I have your message up, it was 883, or even more" Alex: I was I was yeah. so I set my um A1 on high speed which is I think like up to 20 frames a second or something ridiculous. it wasn't shooting anything like that, I don't know what it was shooting, maybe like each burst was about four or five shots um, but the strobes kept up with that perfectly. Um they do lose quite a lot of power when they put them in that mode. I had them on full power and on exposure terms that seemed about equivalent to the HF 1s on quarter power. And remember the hf1 actually have two settings above full, so that's quite a lot of clicks back on the HF-1 that you're going to. I would also say that actually I wasn't shooting close to 10 frames a second, and I think that although people… I do think shooting short bursts is a valuable thing in Blackwater shooting. I think there's a few factors to remember.
This is actually where you 100% confirm my experience with the Apollo III 2.0 ... The Backscatter HF-1 on quarter power will approx the same at 1/4 power as the Apollo III 2.0 at FULL in MTL - It will hold it's stamina at 12fps .CR3 RAWs for approx 1000 frames. And the Apollo holds its stamina: it can keep up at around 12 fps shooting CR3 RAW bursts for roughly 1,000 frames. In my case, the limiting factor is my camera buffer * — not the Apollo III strobe. With the HF-1 set to 1/4 power and trying the same kind of burst, the strobe quickly starts producing blackout frames or underexposed frames every few shots.
* Well,... if you cross 1000 shots the battery cells in any strobe also become a limiting factor.
When there is talk about power drain, I can confirm that firing above 800 shots will drain strobe batteries... but not light output provided in MTL by the strobe. That is until you cross a critical battery level signaled by the strobe indicator light going yellow or purple.
I would observe that we have two independent people stating the HF-1 out performs the Apollo III strobe and one person reporting that the Apollo III is better compared to their HF-1. Surely it's equally possible that the HF-1s in question(or their batteries) are under performing compared to the Apollo III samples as the only data available is the comparative performance of the strobe samples that are owned. It could also be related to the batteries being used in each model as these seem to critical to achieving this sort of performance. Backscatter in particular are quite vocal about using the right type of battery and it's not unheard of for batteries to lose performance after some use.
No please do not get me wrong.
I am not saying anything is better.
The HF-1 is a tick stronger than my Apollo III 2.0 when put to +2 mode and you do not want to utilize burst shooting.
But when you want high fps strobe burst shooting it seems to me that no other manufacturer has mastered this technology than Marelux. Maybe also the other competing companies did just not aim their design at this particular discipline.
And I just want to say that I have noticed that this particular aspect of the product seems to get downplayed in many reviews or comments during the last 1.5 years. Most reviewers seem to have adapted their testing ground to an fps level or use case that the competitor products still can cope with. The only guy who can not be critiqued for being an Ambassador and having written a fair independent review about the Apollo III is Henley Spiers on DPG. Many others seem downplay the aspect and image opportunity of high fps strobe shooting, even if they found the product to perform that decently during their tests. I own and paid both strobes (HF-1 and Apollo III) and think their are both great tools where they go stellar in different disciplines.
My impression is that for some reason I do not understand there seems to be some kind of Marelux or Apollo bashing going on or beeing popular to say - and just few people credit this brand of having introduced a new piece of tech that others still need to catch up to.
The whole thing with the high fps downplay reminds me of my old Hugyfot housing, when that brand introduced vacuum systems on their housings as the only manufacturer around. Everybody else was making fun about them for this and said „our housings also seal without this“. Look now 20 years later and vacuum valves and pumps on housings are a standard. Especially on brands that were shouting Extra loud against them in the period were they did not sell this technology.
Hmmm, not sure I've seen anything I'd call strobe brand bashing. Well not since the old Sea & Sea issue anyway.
Seems to me these are all perfectly good strobes we're talking about. We all have brand preferences based on personal experience, a specific feature or just their good looks. Producing truly accurate comparisons is incredibly difficult given the vagaries of environment, set up, batteries etc. Some amazing work has been posted here by folks who have put hours of work and thought into testing - for which, massive thanks.
After that, yeah, I'm sure one can be tweaked slightly differently from another. But aren't we getting a bit beyond the point? Take your pictures and enjoy them. No matter how perfect the bit of gear might be, something underwater is going to lead to some sort of degradation in perfomance.
All I'm trying to say is two people have done reviews and found the HF-1/maxi performing a little better in the high FPS performance and you have tested and found your Apollo III better. There is the possibility based on this that your samples of HF-1 or their batteries aren't up to speed, just like you suggested that the Apollo III strobe samples one of the testers has were not up to scratch.
To be fair high FPS is not important to everyone I used to use high FPS on land a little and ended up getting sick of examining hundreds of near identical images to pick the image I thought best. But each to their own if you see an advantage to this in your shooting, more power to you. If it's important to you, make your choice of brands that can perform like this using testing like we have seen on this post to guide you.
Chris, no, please stop rehearsing this wrong and changing what was previously articulated correctly.
Two persons who reviewed the Apollo have written in their review that they considered „some sort of settings“ to be better to conduct their review - for some unknown reasons to the public. In these settings the Apollo is not allowed to out-perform the competing products. This is why they were able to win, not because of altered batteries or other reasons etc.
And furthermore it‘s not just one person (me) giving data and honest review about the Apollo III 2.0 strobe. I never publicly reviewed the Apollo or HF-1 strobes. I just used them and can confirm what Henley Spiers wrote in his DPG review about them, which is a neutral undistorted review which really tried to find the performance limit of the Apollo III 2.0 product.
About HF-1: several people and reviews have reported light intensity variation and black frames when trying to conduct high frame rate shooting, for which Dr. Alex Mustard (and me) recommend the 1/4 (or lower) power level on the HF-1 manual switch. This is not a better or worse than fact -Iit is just a very practical piece of information when you want to apply faster frame rate shooting onto subjects in the wild. For me: I prefer reliability instead of luck when trying to nail a certain rare rapid behavior shot in the wild. I want the wildlife subject to be my incalculable factors - not my strobes. This is why I choose the Apollo III 2.0 over the Backscatter HF-1 when trying to get that specific job done right. The RETRAs do not seem to behave better than the HF-1 in this discipline which basically rules them out of the equation for me.
I would need to get my hands on a RETRA Maxi myself, but already the very thorough and critical review of Dave Hicks and also the retra-enthusiasitic review of Kilii Yuyan show that the Maxi is not going to work as a high fps strobe or at least trying to play in that product category. Both reviews give appropriate credit to it in the maximum strobe output category where it goes head to head with the Backscatter HF-1 though.
Looking at HF-1 pricing and RETRA Maxi in February 2026 you will have to pay a few hundred dollars / euros more to have RETRA written on it.
What do you get for this? I see the following:
1.) RETRA Bluetooth cellphone App to check the status of your strobe (nice!)
2.) silver instead of black design
3.) nicer underwater buoyancy (almost neutral) archived by a much more beefy design (makes it less easily fit in your backpack)
what you sacrifice:
1.) 365 EUR (HF-1 price in EU vs MAXI)
2.) an easily accessible boost mode to make it perform brighter than HF-1 or Apollo III 2.0
3.) Backscatter‘s very practical & handy REM (remote mode) feature, which allows you to wirelessly control strobe power without cables.
Can you please give a link to the second review/comparison of the retra Maxi strobe (I cannot find it via google)?
Thanks, Wolfgang
Btw: has anyone used the Retra in TTL mode with Canon mirrorless yet?
Important Information
