Preview of the Retra Maxi Strobe
Featured Replies
1 hour ago, waso said:
Btw: has anyone used the Retra in TTL mode with Canon mirrorless yet?
Came here to ask the same question. Currently shooting with Panasonic GH7 and Inon Z240/Keldan 4 series, and I'm really interested in simplifying with a hybrid strobe. The options are the HF-1 or the Maxi, and I'm leaning towards the maxi but I'd love to hear some TTL experience since that's how I generally shoot.
  • Replies 123
  • Views 7.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Kiliii Yuyan
    Kiliii Yuyan
    Hi everyone, I just did a pretty extensive review of the Retra Maxis compared to several other top of the line strobes, using quantitative methods in a studio. I reckon it's a good counterpart to Dav
  • Dave_Hicks
    Dave_Hicks
    I updated the Power Level comparison, trying to find a better and cleaner way to visualize the range and alignment of power levels across the three strobes being compared. Feedback is welcome! (PREVI
  • Dave_Hicks
    Dave_Hicks
    Sharing are a few more wide-angle shots with the Maxi's. The water conditions around the PNW tend to be fairly particulate at the best of times, so I normally like to use reductions rings. The Maxi
Posted Images
  • Author
In a few days I am leaving for a three-week trip to Raja Ampat. Nine days at Misool Eco resort, then 9 more days on the Emperor Harmoni liveaboard. I've only been shooting the Maxi's in darker cold water with limited visibility. Using them in bright clear conditions should add some additional perspective and the high dive count will be a good measure of their reliability and battery capacity.
I'm doing my packing for a trip today and considering what to bring along. My current planned camera loadout is looking like this:
  • Nauticam Z8 system
  • 2 Retra Maxi Strobes
  • 1 Backscatter Atom Strobe with adapted OS-1 snoot
  • 1 Backscatter MF-2 as an additional backup strobe
  • Nikon Z105mm macro lens w/MFO-1
  • Nikon Z24-50mm w/WWL-C
  • Nikon AF-S 8-15mm w/140mm dome
  • Macro setup with the Atom + Snoot for primary, Maxi with macro rings for secondary
  • Wide angle setup with the two Maxi's, optional reduction rings & filters
I've shot the HF-1s lots of times in these conditions, so I won't bring them on the trip.
19 hours ago, Adventurer said:
Chris, no, please stop rehearsing this wrong and changing what was previously articulated correctly.
Two persons who reviewed the Apollo have written in their review that they considered „some sort of settings“ to be better to conduct their review - for some unknown reasons to the public. In these settings the Apollo is not allowed to out-perform the competing products. This is why they were able to win, not because of altered batteries or other reasons etc.
@Adventurer again people have been posting their test results to the forum using their own strobes and a supplier provided strobe in the case of the maxi and taking a lot of time to test and compile results to benefit the forum participants. You however again imply an ulterior motive as the reason the Apollo III strobe doesn't win. As far as I can see the reviewers have detailed what their methodology has been and reasons behind it.
Please if you disagree with results or methods don't accuse (or imply) people of having ulterior motives, rather address the issue you have with their methodology, why you disagree with the methodology and what you suggest they should do instead and why. You can also agree to disagree. Implying ulterior motives is a form of ad hominem response and we discourage that on the forum. We are all for vigorous discussion about the subject being discussed as long as it is directed to the subject not the forum member.
As far as my question , I believe it a statistical possibility that can't be resolved with the samples at your disposal. You can only draw conclusions based upon the strobes you actually have available to you.
As far as a fair way to compare - my thought is that determining the max power level at which the strobe can rapid fire without dimming or dropping frames at a given frame rate (10 frames/sec , 5, 3 whatever the reviewer chooses) and comparing the light output when firing at that rate makes the most sense. The strobe with the highest light on the subject under those conditions wins. Any tests with dimming and/or frame dropping just makes a lottery of whether your shot is exposed correctly or not.
Dave, we were on Harmoni last year. Brilliant! Best liveaboard we’ve done.
This is exactly what I did back in 2024 when I was testing the strobes. I chose continuous shooting rates my Canon could support (3fps, 6fps and 12fps) and then for each strobe dialed down the power until it could keep up with that frame rate without any black frames for at least 20 frames in a row. Once I established what the setting/power level on the strobe was, I measured the GN of the strobe firing at that setting.
What I observed is that while it's indeed true that some strobes prioritize firing on each shot even at lower power (HF-1) while others (Apollo III in MTL) prioritize trying to keep all exposures evenly lit by not firing at all on some exposures to fully recharge their capacitor before firing, the end result once you dial down the power sufficiently is the same and indistinguishable -- a series of shots that are all lit with minimal exposure variance.
The other thing I noticed is that pretty much every strobe starts out brighter for the first 2-3 shots in the series and gradually dims until shot 10 or so in the series after which it basically settles into a steady-state brightness for the following 20 shots. I measured the brightness based on those latter 20 shots where the shot-to-shot variance was low.
I'll be the first to concede that this is more of a technical capability test than a real life test, in that probably if you're really shooting high frame rates to capture behavior, what you care about is the first 10 shots, not the tail end when the strobe settles into steady-state. And there may be real difference in how each strobe handles those first 5-10 shots. I wasn't testing for that per se.
Finally.. yes, I had one of the earliest production batches of the Apollo III strobe, before they came up with a 2.0 version. But as far as I know, the 2.0 version is physically identical, the only changes are to the wireless control protocols. Light output and recycling time should be the same between the two models. (Gemini claims: The main difference between the Marelux Apollo III and the Marelux Apollo III 2.0 is the updated wireless communication system and internal software that improves stability for various flash modes. The 2.0 version was primarily introduced to allow better integration with the Lumilink 2.0 wireless transmitter.)
My theory is that the HF-1 is able to put out more power in high frame rate mode because of better batteries -- I was using the HF-1 with the nitecore 6000mah 21700 batteries, while the Apollo III had 3 generic 18650 batteries that it came with. Believe the 21700 batteries are just newer/better technology.
Thanks for this, though possibly better 18650 batteries may now be available? I suspect you method has some validity, if the strobe has more power in your test it probably is also brighter in comparison for a quick burst, but I guess it depends on how the strobe is programmed to deal with continuous shots. In addition using 3 18650 (assuming) in series, the voltage is higher so less demanding on amp draw.
Thanks Dreifish, the above is something I did notice on the HF-1 but not on the Apollo III 2.0 that I happen to own. This is why I recommended to get your strobe checked. I am aware that the 2.0 in official documents just refers to the wireless protocol but from what you describe, I would not rule out that there is also other improvements in the product or the chance that you received a „Monday model“ series, as we say in Germany. The findings in Kiliis and Henley Spiers reviews that included Apollo also point into that direction, that it‘s not flawed.
Have a look at the Henley wall projection MTL 12 (full power in fast mode, that is):
source: DivePhotoGuide.com
The variations or blackouts I get on my two HF-1 strobes (and the HF-1 of my friend) are extreme compared to the Apollo III 2.0 - pretty much like the the Retra and OneUW blackouts and light variations in the DPG reviews. I used the fully charged recommended batteries that are in the Backscatter manual for the fast shooting high fps test.
Another potential conflict I would like to put the spotlight on is the fps you can set in the cameras vs what the strobe manufacturers guarantee you.
I think MARELUX will grant you 10 fps solid according to their manual in full MTL power. But like your camera I just have the option available to to do 7 fps or 12 fps on my R6 Mark II. That said, the Apollo‘s kept up with Zero blackout frames @ 12 fps. I explored that mystical feature further by digging into the real net frame rate that our Canon cameras will offer. Canon says the fine wording „up to“ depending on settings and batteries used etc. When shooting a stop watch on my iPhone at the high fps setting I found that the camera actually varies in speed between 10.5 to 12 fps in series burst shooting with strobes. This explains to me why the Marelux Apollo III strobes on my desk seem to be able to easily keep up with this pace. It looked like camera and strobes could do this endlessly forever so I stopped the test after a few hundred RAW .CR3 frames and seconds.
Coming back to the HF-1 and blackout frame behavior there is also a 2nd source online confirming my experience with the other pretty fast strobe in the leading gang,… Nicolas Remy digged into the high fps possibilities of the HF-1 and also confirmed blackout frames and light Variations, which I do not experience with Apollo III 2.0 in MTL. Have a look:
Full HF-1 review on: theunderwaterphotographyclub
Hybrid Flash HF-1
Table 2: Hybrid Flash recycle times and number of flashes at the three most powerful settings (source: Backscatter)
Power Setting
Burst Speed
Light Decrease Between Shots
Number of Flashes Before a Black Frame
Frequency of Black Frames After First One
Total Number of Shots Taken
Comment
1/4
10fps
Smooth
9
Every 2–3 shots
49
1/4–0.5 f-stops
10fps
Smooth
14
Every 2–3 shots
42
1/8
10fps
Very smooth
43
None
43
1/4
8fps
Smooth
16
Every 4 shots
37
1/4
6fps
Very smooth
24
None
37
Decrease during first 24 shots, then stable
1/2
5fps
Smooth
5
Every 1–2 shots
26
1/2
4fps
Very smooth
7
Every 3 shots
25
1/2
3fps
Very smooth
13
None
25
Decrease during first 13 shots, then stable
F
3fps
Noticeable
2
Every second shot
15
Well, I picked up a pair of Maxis that I had ordered way back in December 2024. I did a short use test against the HF-1 and decided the Maxis would be a better choice, plus I got the original launch price (pre-tarrifs too).
I've been doing some TTL tests using a GH6 and the TRT O Smart 3 trigger and I'm pretty happy with the results. One thing that I like on the Retras over the HF-1 is that the retras let you adjust the strobe power up and down in TTL (which is nice for some creative shots). My old Inons could do this too. Another thing that is nice is multiple levels of video lights compared to the HF-1 and finally the extra buoyancy from the Retras.
To be honest, I didn't get a chance to do detailed tests of the RC mode ("wireless) using the TRT and the HF-1. Conceptually I understand what it is doing differently than the mimic TTL I'm just not quite sure how that works in practice. I'll be diving with these in April so I'll have some more details.
@Adventurer
Glad you like your Marelux Apollo III's so much. I think we're past the point where you're convincing anyone of your position - rather just starting to sound a bit pedantic.
I will give you this - Marelux makes a world-leading product that no one is talking about. Their rollerboard carryon will fit a housing (with handles on), 2 strobes, a port, a viewfinder, and several other odds and ends.
It's international sized - however it's a touch wider that virtually anything else you can find on the market. It fits my Nauticam housing and retra strobes really well - I travel with it everywhere...(including this week in Misool).
6 shooters here, no Apollo's, a few Retras, some Inons, etc.
Edited by OneYellowTang
Please everyone, let us avoid personal attacks and, if there is still more to discuss, let us return to the technical aspects!
Some of our members have done their absolute best to test these strobes to the best of their ability, but none of us is a certification body. I am sure that the tests performed, despite their limitations, combined with your own personal experience can give you a clear idea for your next purchase.
And anyway, my G.A.S. has never wanted too much technical information. I just swipe the card and that is it! 😉
You’re right — sorry. I got a bit carried away.
That said, I’d genuinely like to hear more thoughts on strobe design philosophy from people who owned the Retra Pro Max II and then moved to the Maxi. Did anyone here make that switch? If so: what did you feel you sacrificed (if anything), and what did you gain?
More broadly, do you think the future of strobes is primarily Li-ion (18650 / 21700) — and that dual-AA designs will slowly phase out?
For my own journey (INON S-220 -> Apollo III 2.0 -> Backscatter HF-1), it’s a bit like driving a good electric car: once you’ve experienced the convenience, it’s hard to go back. The ability to shoot most of a dive day — sometimes multiple days — without opening the battery compartment is a genuinely pleasant experience.
Just to put some numbers on “stamina” (manufacturer-rated flashes; conditions obviously vary), here’s what I’ve found listed at/near full power:
  • Retra Pro Max II: 300 flashes
  • Backscatter HF-1: 375 flashes (BOOST +2)
  • INON S-220: 500 flashes (FULL)*
  • Retra Maxi: 550 flashes (FULL)
  • Apollo III 2.0: 800 flashes (FULL M)
* Reality check from my dives: I still swap batteries in my INON S-220 before a third dive if I don’t want to risk running out during that dive. So the 500 flashes on the INON maybe archived in a lab type test but in practical diving I feel it lasts substantially less than the new 21700/18650 strobes. With Li-ion strobes, I can often shoot for several days without changing batteries.
Working theory: part of the difference might be standby consumption during the dive (keeping the capacitors topped up / ready between flashes). If that’s true, the higher-capacity 18650/21700 designs could have a real advantage here.
Edited by Adventurer
added stamina thoughts
Unfortunately, there seems to be no experience with this topic in this forum.
For a one-size-fits-all strobe solution, TTL is a must have for me and therefore I will probably buy the HF-1.
I would expect that the TTL of the maxi would use the same protocols as other recent Retra strobes. I found this reference to TTL performance of a 4th generation Retra here:
Thanks!
Do you know by heart which camera and which TTL triogger fruehaufsteher2 uses?
I can't find any information about that quickly.
3 hours ago, waso said:
Thanks!
2 hours ago, Chris Ross said:
sorry no, best to DM I think, you could try looking through his posts you might see something there?
2 minute job. UWT trigger and A7IV.
Okay, thanks, then unfortunately it's not relevant for me.
It's true, it's a confusing domain. I've used Inon Z240s for years with the Panasonic mini flash on a GH-5, and only last year did I switch to a TRT turtle trigger, and now with the Retras. With the TRT you do have a setting for each strobe type, but I'm not quite sure what the sauce they are adding per strobe. With the HF-1, you have backscatter's sauce in the strobe and depending on the trigger (an actual mini flash, backscatter's trigger or the TRT one there are few points for issues.
In any case, for the most part I'm seeing good exposures with the Retras in TTL, although I do dial down the power a bit because they shoot brighter than my Inons. Also this test was on land so it's not quite real world.
I'm wondering about how the video lights are on the Maxi and haven't seen it discussed much. From the layout, it seems they would not have an even light pattern at all. I assume they are not Keldan quality but are they really just dive lights or are they usable for video? Love to hear impression's of those who got them with the 6k video lights.
The video lights seem great. The more yellow photo is from Keldan Luna 4. I don’t see much change of brightness over +0 but I’ll play some more. If there are other good tests to do let me know.
It is possible that it is not getting brighter than 0 to reduce heat in the air. I'll try in a water environment.
I think the batteries weren't fully charged so the lights weren't at the fullest.
  • 1 month later...
Hope this is not too basic a question for this very technical thread - it’s been an interesting read and thank you for the time and effort many of you have put into testing these strobes. I’ve had a couple of Inon Z330’s since 2017 and one of them has started to flicker (red power on light) when I touch the power switch. So thinking it might be a good excuse to upgrade to the Retra Maxis.
I have never really felt the need to shoot at high FPS in the past, but as a simple comparison between the Inon and the Retra, will these be a noticeable upgrade in terms of quality of light, power (obviously), usability, anything else? I have a couple of smaller Kraken strobes for macro, but if I’m going to buy some new ones for wide angle, I’d prefer to pay a bit more for something that will last and hopefully make a difference.
I would appreciate any thoughts.
Paul
I went from Z240 to a set of Retra pure strobes, which are about maybe a stop and a bit below the Pro-maxII strobes, If I recall the maxi was ahead of the Pro-MaxII by a near a stop. My strobes are certainly brighter than the Z-240s by maybe 0.7-1 stop and Z330 are probably as bright or a little brighter than my Pure strobes. The Maxi is 1.5- 1.7 stops fatter again, so comfortably faster than the Z330. I've only used up to half power with them so far, while I was half a stop below full power withe Z240 a lot of the time.
As far as light quality goes the Retra Maxi seems close to the ProMaxII (and my Pures) which is comfortably better than the Inon Z-240 for me. The Z330 I think is on par with the Z240 for light quality. The thing I did find is that with the reduction rings, with reasonable strobe positioning there is a lot less backscatter - instantly noticeable, both shooting in Lembeh and around Sydney in the temperate waters where particulates are a constant problem.
Important Information
