Proven 3D printed Parts For Underwater Imaging
Featured Replies
2 hours ago, Giancarlo M. said:
Quick heads-up for Sony + Metabones + Canon 8-15mm users: I found this very interesting model. Please note: the locking mechanism is missing
LOL. That's my model upload. Yes, you'll need the locking mechanism or download one for use. I used the one from the OEM gear and it works well. I found the OEM gear that used the zoom knob on the 100-120 adapter was a bit clunky and not very smooth as the gears are aligned at 90-degrees, I extended the gear to use the zoom gear in the housing which is linearly aligned and much smoother in operation. Additionally, you can install the entire camera/lens assembly without assembling from both the front and rear.
  • Replies 177
  • Views 46.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Tino Dietsche
    Tino Dietsche
    Hello everyone, Since my used Nauticam WWL-1 lens didn't come with a back cap, I made a suitable one. It also works for the bayonet mount. I hope someone can use this. https://makerworld.com/en/mo
  • Tino Dietsche
    Tino Dietsche
    Hello everyone, I've designed another new part that might be helpful to others here. The tip of one of my Nauticam hand pumps for the vacuum system was broken and cracked. I didn't want to buy a new p
  • brightnight
    brightnight
    N120 body cap found on Thingiverse worked for me:   https://www.thingiverse.com/thing:5326351/files         Files attached too: Nauticam N120 Port Cover Male
Posted Images
I just shared a couple of new Nauticam / Nikon Zoom Gears on Makerworld.
Nikon 8-15mm with 1.4 Teleconverter
This is a great lens combination that will give you a little more reach with the excellent 8-15mm fisheye lens and Kenko 1.4TC. (other TC's may work, assumes a 20mm length) While the 8-15 is a zoom lens, it's really just 8mm circular or 15mm wide angle. Many people dislike the circular effect, but it can be a fun party trick. However, adding a 1.4 TC gives you some more reach in the wide angle mode making the zoom function much more interesting for this lens. Be careful not to zoom in too much and vignette the edges.
https://makerworld.com/en/models/2594402-nauticam-zoom-gear-for-nikon-8-15mm-with-1-4-tc#profileId-2862921
Nikon 14-24mm Z-mount
Zoom gear for the Nikon 14-24mm Z-mount lens. Note there is also a 14-24 v2 lens which would not work with this gear.
https://makerworld.com/en/models/2584588-nauticam-zoom-gear-for-nikon-14-24-z-mount-lens#profileId-2851033
More Scuba and UW Photo designs:
Scuba: https://makerworld.com/collections/16165676
UW Photo: https://makerworld.com/collections/16165730
Edited by Dave_Hicks
Nice project! Unfortunately, I have two original Nauticam blocks, but they're too thick and don't fit the 8-15 or your design. For now, I've cut a piece of rubber to size and it's working, even if it sometimes shifts a little.
It would be great if you could recreate that piece in 3D as well; everyone would really appreciate it
Edited by Giancarlo M.
  • 2 weeks later...
Hi
has anyone aliready designed of found a Nauticam zoom gear for Sony 16-35 f2.8 ?
Perhaps also a combo with focus gear for the same, but probably difficult as they overlap...
  • 2 weeks later...
6 minutes ago, deliamaria said:
Has anybody made a focus gear for the nikon z 50mm f/2.8
I've not seen one. It's not a common lens in UW use so far. It's not hard to make one, but you need to have one in hand to take the measurements.
On 4/16/2026 at 3:24 PM, FrancoisC said:
Hi
Which one, GM or GMII? I have a GM version but don't use it underwater. However, I can do a design for you,
  • 2 weeks later...
Does anyone know of a good model for a Nauticam focus gear to fit the Nikon 105 Z macro lens?
I have not seen one, but i have the lens and can knock out a gear for it tomorrow. I will post a link once i get the model uploaded. For Nauticam.
Thanks! Somehow, between searching and posting, I had missed this model: https://makerworld.com/en/models/2733718-nauticam-focus-gear-for-nikon-z-105mm-macro-lens, although I don't currently have a great way to test it out.
  • 1 month later...
  • 4 weeks later...
Potentially not the most useful, but has anyone made a focus ring for the Sony 100mm f2.8 GM macro lens? I imagine I'll nearly exclusively use auto focus but if there's a ring that's easy to print it'll be kind of nice to have the option.
45 minutes ago, Landvogt1893 said:
Does anyone have a protective front cover for a Retra Pro Max to protect the lens during transport?
Do you have a diffusor?
Yes i have.... sometimes the simplest solution is right in front of you. :-)
Edited by Landvogt1893
building off of this, a ring specifically for the 1.4 and 2.0 TC's would also be nice. I've always wondered if it would be possible to make focus ring extensions for this very purpose.
I've been wondering if a magnetic focus gear like Inon uses in their MRS system would be possible to adapt to other housings. Then you don't need a different gear when changing extensions or adding TCs.
Just an idea I've had in the back of my mind.
Hi everyone,
I am looking for a 3D printable file (.STL) for a Nauticam zoom gear for the Canon EF 8-15mm f/4L Fisheye USM lens.
I am using it inside a Nauticam NA R6 housing with an EF-RF adapter and a Saga 4" Minidome.
Does anyone happen to have a tested file or a parametric design they could share?
Thank you so much for your help!
On 3/20/2026 at 8:59 PM, Tino Dietsche said:
Hello everyone,
My protective ring for the Nauticam MFO-3 lenses is now available online. The basic design idea comes from "flowdesign," whose ring I also used for a while. Tanks for this!
Since I've designed various things for SMC, MFO, and CMC lenses, I completely redesigned the protective ring.
Now I have excellent protection for my MFO-3 lenses both in the water and during transport.
Tino
https://makerworld.com/de/models/2548785-lens-bumper-for-nauticam-mfo-3#profileId-2806849
Cover for MFO-3 mounted on Nauticam Bayonet-Adapter for Transport
MFO-3 Deckel.stl
Hi Tino
I've just have this printed in China (JLCPCB) but not sure how it works.
On my print, the larger ring slips off the smaller retainer ring - did you glue it on?
Or maybe I'm mounting it wrong / the material used.
thanks!
WhatsApp Image 2026-08-23 at 16.12.11.jpegWhatsApp Image 2026-08-23 at 16.12.12.jpeg
EDIT - after trying multiple combination I managed to make it click on somehow, but not sure if this is the "correct" way, as it looks a little different from your pic:
WhatsApp Image 2026-08-23 at 17.13.46.jpegWhatsApp Image 2026-08-23 at 17.13.47.jpeg
Edited by bghazzal
  • 1 month later...
